Message 1 of 2
How can i keep my fax line phone number after "switch off"
Hi
Regarding the PSTN  - We have a fax line line, albeit that does not get used, however we would like to keep the number as it is relevant to our business. As we dont use fax anymore is there a way of keeping the line number so that we dont lose it altogether ?
1 REPLY 1
Message 2 of 2
Re: How can i keep my fax line phone number after "switch off"
There is nothing special about a fax line , it’s a standard PSTN  ‘line’ that you had a fax machine connected to , so from a migration to DV point of view, it’s no different, provided it’s a residential service , if it is residential and you want to keep the line its migration to DV will be no  different to a telephone line , however if you don’t have a broadband service associated with this fax line , or if it’s recorded as a business, it’s not likely to be migrated anytime soon because of the lack of broadband or  the business tariff associated with it ( or both ) .
The removal of PSTN lines for businesses is likely to be different to its removal for residential lines , and non broadband residential lines are not currently being targeted to move to DV .
