Message 1 of 2
Hub6 used - don't want DV
I use the hub 6 here as we require different 2.4/5GHz band naming. I don't want to downgrade to the Smart Hub 2.
We tried the Smart Hub 2 during so connection issues but several devices would not connect via WiFi including the Box Pro.
We also do NOT use a telephone on the BT landline - not even one connected.
I see some people are now being switched over to DV but the hub 6 do not have a dv socket.
I take it I can keep the superior Hub 6 active without DV or telephone in the future?
1 REPLY 1
Message 2 of 2
Re: Hub6 used - don't want DV
@ozsat
You do not need to use DV, in fact you can get broadband without any phone service if you want, when you renew your contract. It saves about £5 a month.
You can keep using your HH6.
