Message 11 of 28
Re: If BT Router is not used, how long will Call Divert settings function for?
You will need a BT Digital Voice handset to disable multi call.
The DV handset also has a built in menu options for call divert which may be the reason for your problem if you are using a normal DECT handset to initiate the diversion.
Message 12 of 28
Thanks for this.
So I would need to buy a BT handset to ensure the settings are maintained, that's a shame.
It is strange though, especially as the way I configured it was via the old method that appears to still work: *21* [enter telephone answering number] #
Message 13 of 28
Can you just borrow a handset from someone to disable multi call and enable call diversion.
Message 14 of 28
Unfortunately not, I don't know anyone with one.
Message 15 of 28
Amazon do corded phones starting at £7.
Message 16 of 28
@gg30340 It's a DV phone that is required.
Message 17 of 28
Do they not work if plugged into the rear of the SH2.
Message 18 of 28
See message 11
Message 19 of 28
Noted. I just skimmed through without taking it in.
Message 20 of 28
Hi @licquorice
The Call Divert has stopped working again, tried it within the last hour and when I ring it from a different phone, it does not ring, just does beep beep beep continuously. So this time the settings were retained for around 24 hours.
If you could contact a mod, I would be grateful, otherwise I'll get a second hand BT phone and do the multi call thing you mentioned before.
Thanks again for your help.
