Message 11 of 48
Re: Incoming calls cut off after 1/2 hour
Hi @HoodedOracle
Thanks for posting back!
I am sorry that you're still having problems with this.  I can understand the frustration due to the length of time you've had this problem.
Please send over the details and we'll help you again. See: Private messages
Thanks,
Robbie
Message 12 of 48
I realise that this is an Old post, but please can you tell me how the problem was resolved.
Thanks.
Message 13 of 48
Hi @5progface.
I'm sorry to hear you are experiencing issues with calls cutting out.
Does this only happen with incoming OR does it occur with outgoing calls too?
I can also see you have reported this previously, what was advised by the agent?
Speak soon,
Katie
Message 14 of 48
This only happens on incoming calls from Australia.
Advised that it may a fault at Australian end.
My daughter in Australia reported this matter to Telstra, they could not find any fault.
The calls cut off a few seconds before and a few seconds after the 15 minute mark.
My internet speeds on upload are  between 11 to 15 Mbps.
I was hoping that after two years of this matter being reported by other users, that there was a solution available.
Thank you for your reply.
Message 15 of 48
Thanks so much for getting back to me @5progface.
It does sound like this could be a problem with the international number that is calling you.
Does it happen with one specific number?
Has your daughter tried calling from another?
Katie
Message 16 of 48
Thanks Katie.
My daughter uses two different mobiles to call me.
Each with it's own number.
Message 17 of 48
I'm not sure what could be causing this @5progface.
If this happens with multiple international numbers it could be worth speaking with our technical care team again who can complete a full diagnostics.
Please keep us updated following your call.
Katie
Message 18 of 48
Thanks Katie,
tests were done yesterday, no fault found.
Regards,
Len.
Message 19 of 48
Vodafone in the UK refused to acknowledge they had a problem with mobile calls terminating after 30 minutes. I'm not sure if this is still the case but a search should provide more info which may be relevant to the Australian mobiles - the provider may also be in denial.
Message 20 of 48
I changed to digital phone. No more issues. Just if there is a powercut, no phone. So Keep mobile charged! Or pay extre for baytery backup.
