Message 11 of 15
Re: Lost landline
With regards to the checker.
only thing unavailable is WBC FTTC
FTTP is available and new ONT may be ordered
FTTP has priority over other products
WLR is available
SOADSL is restricted
Message 12 of 15
Re: Lost landline
In regards to checking to see if the number is available. If I ring customer service would they be able to tell me if they can do it before I place the order?
Message 13 of 15
Re: Lost landline
Try them and see.
As I see it, you have to decide if you wish to stay with Virgin and 100% lose the number or switch back to BT with a slim chance you might be able to retrieve it. Depends on your reasoning in switching in the first place and how important that choice was compared with losing the number.
Message 14 of 15
Re: Lost landline
@Simmons0001
If FTTP is the only option available, its likely to take some time before this could be installed, provided there is a suitable entry point for the new fibre connection. You could be without broadband for some time, especially if you have to cancel Virgin within the cooling off period.
As for keeping the number, you could always ask.
Message 15 of 15
Re: Lost landline
Hi @Simmons0001, if it's going to be Digital Voice they'll be able to tell you about the number during the order journey. If they can't allocate it then it's likely the number won't be able to be retrieved.
John
