Message 1 of 5
Making calls
All calls from my landline result in an engaged tone including calls to my cellphone. Any ideas?
4 REPLIES 4
Message 2 of 5
Re: Making calls
@19towser41
Do BT Retail provide your phone service?
If they do, then dial 17070 and make sure the number that is read back to you, matches your home phone number, jus in case you have a crossed line.
Message 3 of 5
Re: Making calls
Thanks for suggestion, but still get engaged tone.
Message 4 of 5
Re: Making calls
@19towser41
Was the number read back to you the correct number?
Are you on BT Digital Voice?
Message 5 of 5
Re: Making calls
It turns out that the problem was a fault in the local exchange.
