Message 1 of 1
CALLER DISPLAY
My caller display show incoming mobile calls as 'UNAVAILABLE'  Landline incoming calls are displayed correctly.
Bt help disconnected Caller Display, reconnected it but no use.  I have replaced all batteries in handsets (three) one base with answer machine and two others in bedrooms.  I have also tested these individually (by removing batteries from two)  I get an E mail from BT saying your Caller Display is now up and running but mobiles still come in as 'UNAVAILABLE.   I check * hash 234 hash -- It says  'caller identities will be displayed''    but they are not.
I have also disconnected phones from main socket turned off power and reconnected, but it makes no difference.
Any suggestion would be very much appreciated
