Message 1 of 6
Malfunctioning BT4600 handset
One BT 4600 handset doesn’t work. If you press Green it says “playing” and then plays a message from 14 Feb pm and doesn’t let you do anything else. I have removed the batteries and put them back and nothing changes. Cannot see how to reset the handset. The other handset is working perfectly.
Tags (3)
5 REPLIES 5
Message 2 of 6
Re: Malfunctioning BT4600 handset
@Fiona30
Welcome to this user forum for BT Retail phone and broadband customers.
The first thing to do is to power down the base unit for about a minute, so the handset link is re-initialised.
If that does not fix the problem, then try the helpdesk.
Product helpdesk information
If your phone is within warranty:
By phone: 0800 145 6789
Monday to Friday 9.00am to 5.30pm, Saturday 9am to 2pm
By email: Click here for email support
If your product is out of warranty contact BT's recommended agent
By phone: 0800 980 8999
Anonymous
Not applicable
Message 3 of 6
P.72 of the manual.
Message 4 of 6
Thanks for the reply. It didn’t work - it still goes straight to the old answerphone message. I will ring the product helpline, thanks.
Message 5 of 6
That also doesn’t work. I cannot access the menu. If you press any button it goes to the answerphone message.
Message 6 of 6
Thanks to the product helpline who confirmed it has malfunctioned and replacement handset has been ordered
