Message 11 of 12
Re: Move Broadband, keep landline ?
I think this would be the way I should have gone with this.
For future reference:
  • I still was on copper connection not Digital Voice
  • I wasn't trying to move the number to Virgin, you can't with a 5X box yet. I wanted to keep BT because of that.
  • The BT operators handling a cancellation are just call center people using a script. You cannot trust them to do anything  outside of filling in your details.
As my Phone Line with its number is down as cancelled it's unlikely I could get it transferred anywhere now so I'm giving up.
Message 12 of 12
Were you told what the price was going to be for BT telephony without any BT  broadband service ? you never said the price or if this was discussed ( you said that they confirmed you could continue with telephone only but you at what price ? ) if the price never came up , it’s not surprising that you lost telephony  as well as BT broadband,  FWIW , as you have broadband from Virgin , the telephone only discount for BT customers without any broadband from any provider wouldn’t be available so the saving would have been hardly worth the effort of removing broadband in the first place , in the order of £1-£2 a month .
