Message 11 of 18
Re: Moved to DV & Updated to FTTP
A factory reset would have been a better option, as that is the only way to clear the DHCP table.
Message 12 of 18
@Keith_Beddoe - Noted, If I do a factory reset now would that affect anything on the phone (DV) connection to HUB.
Message 13 of 18
It will delete any contacts you have entered in the phone, however, the contact list can be backed up before resetting and restored afterwards. It will also require the DV handset to be registered to the hub again.
Message 14 of 18
@licquorice - Thanks for your reply, noted info appreciated. Will think it over now, nothing straight forward now with BT recycled Hub / power supply cable supplied no booklet manual etc for unit.
Message 15 of 18
You don't need a manual, there is very little configuration you can do with the Hub and the menu options are straightforward and intuitive.
Message 16 of 18
This is interesting. I've just connected up the Smart Hub 2 in anticipation of  DV next week. (Sad to see myTP Link VR400 go, it's been great) I have exactly the same devices appearing as @clique-al in my list. Could this be equipment they use for testing refurb hubs?
Message 17 of 18
if that does not mean anything to you then I would factory reset the hub by pressing the recessed button on the back of hub and hold for 20/30 secs until hub lights flash  then reboot hub and should be completely clear
if you have a lot of wifi devices I would change the hub SSID to that of your tplink and also use the existing wireless password and that way your wifi devices will connect as if there had been no change
Message 18 of 18
@imjolly Thanks for that. I have just Factory Reset the Hub and it is  now completely clear.  Whatever the reason these devices were there it now makes it easier to keep a track of all the devices that should be there.
