Anonymous
Not applicable
Message 11 of 22
Re: Moving Master Socket (without additional wiring)
@SteveG2460
Do you know who installed the hidden existing cable between your master and slave sockets?
It might be possible for Openreach make a joint between the two cables at your existing master socket, but they might not be happy to use cable that they did not install themselves.
If you are not confident with following @licquorice's instructions, then as that work would solely be on the customer's wiring, you might find it cheaper to get someone locally to do it. Try a web search foe "Ex BT Engineer" etc - there are a lot of them about!
Message 12 of 22
If @SteveG2460  has an unfiltered master socket, there is nothing to do. Simply unplug the router and plug it in in the lounge.
Message 13 of 22
Many thanks for your advice Paul08085
Message 14 of 22
Why do I bother?
Message 15 of 22
@licquorice wrote:
Why do I bother?
Some people just like to take the route that costs money because they think if you pay for it it must be the best route even if its not needed.
Message 16 of 22
Maybe if you were a little more polite people might listen to you.
Message 17 of 22
If that was directed at me you will notice that I thanked Paul608085 for his advice about contacting an ex-BT engineer and I will explore that route.
Message 18 of 22
If you simply answered the question I posed, there is a possibility that you don't need to contact anybody and simply unplug the router from its existing position and plug it in the new, but feel free to continue ignoring my advice.
Message 19 of 22
I was about to post similar but you beat me to it.
Anonymous
Not applicable
Message 20 of 22
TBH, I had assumed that @SteveG2460 would try just unplugging their router and moving it to the other phone socket before calling someone out - if they hadn't tried that already. (As suggested by @licquorice ).
OP: if you haven't done that already, then try it - you have nothing to lose, it will either work, (in which case, problem solved), or it won't, and you will just need to put the router back as it was and contact someone if you don't feel confident moving the connections, (post #4 in this thread), yourself.
