Message 11 of 12
Re: Moving broadband with Digital Voice from BT to EE warning
Hey there @wilsonmfw.
If you  head over to your Hub manager on http://192.168.1.254/ and select your landline number, it should give you the option to export your contact data, as well as import contact data from elsewhere.
You can then save that to your PC for if you ever need to change Hubs.
Peter
Message 12 of 12
Thank you Peter, sorted 🙏
