Message 1 of 5
New DV phones.
Please..... I live in Eastbourne and am on Fibre using a Smart Hub 2. Can i go ahead and set up BT DV phones or do I need to contact BT and arrange a changeover date?
4 REPLIES 4
Message 2 of 5
Re: New DV phones.
You'll have a digital voice switchover date as until then the Smart Hub 2 won't be configured for digital voice yet.
You will receive an email when your switch over date is nearby
Message 3 of 5
Re: New DV phones.
Hi, @JOHNBYSEA In previous posts I see you've mentioned that you're using a digital voice adapter and DECT phones already. If that's the case a digital voice is active already then you should be able to set up your DV phones.
Neil
Message 4 of 5
Re: New DV phones.
Thank you, Neil.
Message 5 of 5
Re: New DV phones.
Thank you jac.
