Message 1 of 5
No link to base
4 REPLIES 4
Message 2 of 5
Re: No link to base
you need to expand on your problem
if you mean problems connecting dv phone/adapter to SH2 then check that DV has been activated by going to hub manager and looking for your phone number.  will not pair until DV active
Message 3 of 5
Re: No link to base
The phone batteries were dead. I replaced the batteries and hey presto the issue was fixed. The phone is working.
Message 4 of 5
Re: No link to base
This seems to be a common problem with the BT supplied phones, it makes you wonder how long they have been in storage.
Message 5 of 5
Re: No link to base
Hello
Thank you
The issue was due to the batteries- dead
Once replaced the problem solved.
