Message 1 of 6
No link to hub digital voice.
Hi all,
After loads of broadband connectivity problems since switching to FTTP,a replacement Smarthub 2 was deemed necessary.Set it up yesterday,took 6 hrs to connect with hybrid connect working instead but eventually did.However The digital voice phone says no link to the hub despite registration successful.Any advice would be gratefully received.
5 REPLIES 5
Message 2 of 6
Re: No link to hub digital voice.
Message 3 of 6
If your phone number is shown when going into hub manager then select the number and try resetting base and see if that helps. You will have to re-pair the phone which you  can do from the same place
Message 4 of 6
imjolly,thanks for that will try it,only one person will ring it, my 87 year old mother in law.Do I have to have it?
Message 5 of 6
If you want to have a landline  phone then you must have digital voice with BT.  however you can have broadband without the ability to make/receive landline calls but you still need to pay line rental which is included in your package
Message 6 of 6
Thanks for your quick reply.Will try your suggestion.
