Message 1 of 8
Not receiving landline calls from all networks.
I recently had my old BT number ported back from Virgin Media to BT.
I can receive calls from BT landlines and mobiles but calls from Virgin Media and Sky fail saying this number does not exist.
Please can the mods look into this as I have already reported this problem to BT once and nothing has happened..
The fault has not been fixed despite waiting a week and it passing the target date.
I have re-reported the fault which just means it gets shoved back to Openreach again.
I cannot track the fault as the fault number does not show up on my account when I log in.
Many thanks...
7 REPLIES 7
Message 2 of 8
Re: Not receiving landline calls from all networks.
Do you have FTTP and/or digital voice?
Message 3 of 8
Digital voice here.
Message 4 of 8
Then phone the FTTP TEAM who deal with digital voice and they should be able to help.  Appears to be a porting problems which has been posted about before. 08005874787
Message 5 of 8
It's now three weeks since this fault was reported.
BT seem unable to fix or even find the fault.
Please can the mods look into this please?
Message 6 of 8
It's 100% a porting issue like @imjolly  said, you'll be able to receive calls from BT, EE and Plusnet customers, other networks won't connect because the port hasn't gone through correctly.
Message 7 of 8
At last.....
All seems to be working.
Though why it took so long to fix, who knows?
Message 8 of 8
Hi there
I’m having the same issue at the moment so please can you advise what seemed to correct the issue? Thanks in advance
