Message 1 of 21
Number of rings
Hello
Re. Advanced home phone
Can anyone help please?
How do I extend the number of times the phone rings before going to answer phone?
Thank you
Rob
20 REPLIES 20
Anonymous
Not applicable
Message 2 of 21
Re: Number of rings
Owing to BT's inexplicable logic behind applying the same "Advanced" name to multiple products, you'll have to be explicit about exactly what you have. If DV phones then I believe you can modify the number of rings in MyBT > Your Products > DV.
Message 3 of 21
Re: Number of rings
BT Advanced Digital Home Phone: Advanced Phone Trio...
bt item code 090640
Message 4 of 21
Re: Number of rings
You should be able to increase number of rings by going to MYBT as suggested by @Anonymous
Message 5 of 21
Re: Number of rings
Hi, @Rob42233 If you're using the answering machine on the advanced phones page 37 on the user guide explains how you can change the number of rings. If you're using 1571 voicemail it can be changed in MyBT.
Neil
Anonymous
Not applicable
Message 6 of 21
Re: Number of rings
P.37 of the manual.
If you have been migrated to DV  then BT's own 1571 voicemail is active by default. So you'll need to decide which one you want to take messages. If you decide on the DECT unit then you have to set 1571 to maximum rings & the DECT to something less than that.
Edit: @NeilO wins by a nose! 😁
Message 7 of 21
Re: Number of rings
I've switched off the answer machine.
The number of rings was already set to max.
But still only ringing 4x.
It's a phone we bought for my mum (90) as she was having a lot of nuisance calls, and it's worked a treat.
But no matter what I try I cannot get it to ring more than 4x.
Rob
Message 8 of 21
Re: Number of rings
Hi @Rob42233 if you've switched off the answering machine on the advanced phone, is 1571 active on the line?
Neil
Message 9 of 21
Re: Number of rings
You can also change the number of rings before going to voicemail by calling 1571 and navigating through the vocal menu to that option. I did that successfully as soon as I was migrated to DV
Message 10 of 21
Re: Number of rings
  • I'll check... this weekend
