Message 1 of 3
Phone line with external bell, bell tinks instead of ringing
We have this master and only socket.
The other end of the blue/white and white/blue wires is the incoming line.
The other end of the orange/white and white/orange wires go to the external bell
Looking at the wires on the master socket two wires are connected to 5.
Is it correct to have two wires on 5? I was wandering if one the orange wire should come off 5 and be connected to 4?
2 REPLIES 2
Message 2 of 3
Re: Phone line with external bell, bell tinks instead of ringing
Extention bells are connected across terminals 3 and 5. Terminal 4 is used for an earth connection used in older business phone systems
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Message 3 of 3
No, that is wired correctly for an external bell. Its possibly a mechanical fault on the bell.
