Message 1 of 6
Phones connected via DV Adapters not ringing
I have one phone connected directly to my Smarthub 2 green socket and 2 other phones connected via DV Adapters. All of them can place calls OK, but only the phone directly connected to the Smarthub rings with an incoming call.
Am I missing something in the setup - or is this normal for phones connected via DV Adapters?
5 REPLIES 5
Message 2 of 6
Re: Phones connected via DV Adapters not ringing
Message 3 of 6
Try an old filter in the adapter to provide the ring wire
Message 4 of 6
By old filter, do you mean the filters previously used when analogue phone was carried simultaneously with ADSL over the phone line?
Message 5 of 6
Message 6 of 6
Yes, thank you, that worked!
