Message 11 of 12
Re: Porting landline number
As stated, you are asking the wrong people, you need to ask the company you wish to use for VoIP.
Message 12 of 12
BT port numbers on request, AFAIK, it’s not really possible to refuse, ‘ officially ’ number portability should be a reciprocal arrangement, so if a company ‘imports’ numbers from others , they also should be able to  export numbers in the same way , on request,  BT to a VoIP provider is something frequently done  and the VoIP provider , considering pretty much their entire business is built on being able to import numbers from others , should be proficient in the process.
