Message 11 of 21
Re: Question about my fibre and digital voice switchover
@Raj1015 wrote:
Mmmm, what is a high resistance connection?
I did think it could cause problems if my phone line is switched off.
then why is DV being pushed out if people are going to have disconnections when they are on FTTC?
I would rather leave as is but I don’t have a choice as this a national roll out.
Its caused by bad or corroded copper or copper/aluminium joints  in the external network. When there is a voltage on the line, and current flowing, any bad connection is normally "repaired" and the connection maintained.
Once the connection back to the exchange is disconnected, this voltage is gone, so more frequent fault on the line are possible, which can take a long time to find.
An old thread https://community.bt.com/t5/Archive-Staging/Possible-High-Resistance-fault-and-issues-with-Engineer-...
DV has to be pushed out to all connections eventually, as there will be no phone equipment in the exchange any more after 2025.
The reason for this, is explained on this two page website.
https://www.draytek.co.uk/information/blog/the-end-of-analogue-phone-lines-pt1
Message 12 of 21
Ahh, thanks for the explanation, much appreciated.
 I had an engineer out, last month because of a ppp lcp termination request problem which seems ok atm, he said my line to the cabinet and then to the exchange was one of the best he’d tested, so I’m hoping all will be good when I’m switched to DV (or I might change to broadband only package).
Message 13 of 21
I think the broadband only package saves about £5 a month, if you are prepared to lose your phone number.
Message 14 of 21
Yep that’s what it says on Bt website.
I may just keep my phone number though, a bit undecided yet, but just to clarify, sorry if it’s a silly question:
when bt switch me to DV can I then unplug my cordless landline phone and chuck it in the cupboard and my broadband will still work as it has been?
Message 15 of 21
You plug your landline phone base unit, into the phone socket on the back of the Smart Hub 2, and it will work just as it did before. You do not need to do anything else to use your phone service.
Broadband is not affected by this.
Message 16 of 21
Yep I know this but it’s not practical to where my SH2 is and I’m not to bothered about my calls over DV and just wanted to know that if I didn’t connect my phone or any other DV phone to my SH2, would it make any difference to my internet?
cheers
Message 17 of 21
@Raj1015 wrote:
When bt switch me to DV can I then unplug my cordless landline phone and chuck it in the cupboard and my broadband will still work as it has been?
Yes.
If you want you can change your phone package to pay as you go. This keeps your number and option to use the phone if you later want to get it out of the cupboard and use it.
Message 18 of 21
i was just thinking of keeping my number but not connecting my phone to the router, but could if I needed to, but I probably won’t (lol)
Message 19 of 21
You are completely overthinking this, you can do whatever you like with your voice service, it will have no impact whatsoever on your broadband as has been explained several times.
Message 20 of 21
I have seen posts where someone going for the non telephony option ( £5 cheaper ) we’re offered telephony for an additional £2 or £3 rather than £5 ( if it makes a difference ) but if you simply want to keep what you have , but not use the DV phone service, then not plugging anything into the phone socket on the hub won’t affect broadband at all, I don’t know what ‘tone’ anyone calling your number would get , ringtone no reply ( the standard phone service would return that ) or is DV is clever enough to recognise no phone plugged in and would return an announcement like  ‘ the customer called is not currently taking incoming calls ‘  , but if you don’t want DV , but don’t want to remove it either..just don’t plug a phone in.
