Message 1 of 2
Re: BT Phone Problem (Digital Voice) Engaged Tone.
I have same issue. When i first set up the adaptor and phone it worked fine for months.
Now recently I have the continuos engaged tone and cannot use my old phone.
The new Digital phone works fine.
I have disconnected and reconnected to adaptor, but same result with continuous engaged tone.
The phone itself rings when someone calls, but we cannot answer it or dial out.
1 REPLY 1
Message 2 of 2
UPDATE!!.... Plugging phone directly into the bt hub it worked!
Therefore i assume there is something wrong with the remote adapter.
Investigations continue...
