Message 1 of 9
Re: BT landline not available to Sky users
I have the same problem with 2xSky mobiles and a Sky landline not getting through to my BT landline. I’ve spent hours and hours trying to resolve the problem with both Sky and BT to no avail. I think I’m going round the twist!!
HELP!
8 REPLIES 8
Message 2 of 9
As you have a sky landline then as a sky customer you need to phone sky not BT RETAIL as they should be able to fix your problem
Message 3 of 9
Sky won't be able to help, speak with BT again, it sounds like a routing issue.
It would help if you can make a log of what number called you, the network they are on, the error message they hear and the date/time.
Message 4 of 9
My landline is BT
Message 5 of 9
Thanks Richie. I’ve already given them all that information at least 10 times. It’s infuriating!
Message 6 of 9
Hi @FionaK1welcome to the community and thanks for posting, I'm really sorry you're experiencing problems receiving calls on your landline. It sounds like a potential number port issue, has this problem only started after you changed to digital voice or moved your services over to BT?
I'll send you a private message so you can get in touch with the moderation team and we'll be happy to help.
We're very busy at the moment so it will take us a few days before we'll be able to get back to you.
Neil
BT Community Moderator
Message 7 of 9
Hi Neil
Thank you for responding.
Yes, the issue started when I changed over to digital voice.
I would really appreciate your help.
Many thanks
Message 8 of 9
Has the number always been with BT , or at some point was it exported ( possibly to Sky ) and then returned to BT , or has it always been with BT and calls from Sky were never an issue until you were migrated from BT PSTN onto BT DV ?
Message 9 of 9
Yes you’re spot on. We were with BT, changed to Sky then decided to go back to BT. It’s been since then.
