Message 1 of 3
Re: How to Connect my Panasonic Phones when we have FTTP
Good morning dear all, and much thanks for all the work,
When we get FTTP ( and the streetlights go down !) how do I connect my Panasonic Phones and answering M/C currently connected by copper given that we lose the copper line and run on Fiber, all my thanks to you all,  the site makes for interesting reading - regards from Pipeline Taff
2 REPLIES 2
Message 2 of 3
either connect you panasonic base to green socket on back of hub or get a DV adapter and this will allow you to connect panasonic elsewhere in your home
try reading the FAQ which will help
https://community.bt.com/t5/Home-phone-including-Digital/Digital-Voice-FAQs/td-p/2207485
Message 3 of 3
Much thanks for the Answer "we go with Green" and reading your FAQ explained all.With thanks to you all- Pipeline Taff
