Message 1 of 6
Re: My BT landline number isn't associated with my address
Hi there,
I have just recently noticed that I have the exact same issue.
I can't see a contact the moderators link in either profile on this post.
Hope you can help?
Many thanks in advance
5 REPLIES 5
Message 2 of 6
Hi @Ponty500, welcome to the forum and thanks for posting.
I'm sorry that your address details are not correct.
There are a few pieces of information I need before I can advise you further on this.
Do you have a copper landline or are you on full fibre?
Are you A BT Retail customer?
Is your address correctly listed here: Postcode Finder - Find an address | Royal Mail Group Ltd
Cheers
John
Message 3 of 6
Hi John,
Yes I am a BT customer, on a copper connection and yes the address is correct on the Royal Mail site.
Many thanks
Message 4 of 6
Hi @Ponty500, thanks for getting back so quickly with those answers.
We'll be able to get this fixed for you. I've sent you a Private Message so you can get in touch with the Mod team.
Cheers
John
Message 5 of 6
Hi @Ponty500, just an update to confirm that your address record has now been corrected.
Cheers
John
Message 6 of 6
Many thanks for your help John.
