Message 1 of 12
Redundant plug-in phone socket removal
I have FTTP and now on Digital Voice, which makes my old plug in phone sockets redundant, how do I get rid of them and any wiring?
11 REPLIES 11
Message 2 of 12
Re: Redundant plug-in phone socket removal
Message 3 of 12
any extension sockets and wiring is property of homeowner so you can just disconnect and take out if you want.  the main/master socket is property of openreach but unlikely if you nowe have FTTP that openreach are going to come and inspect your property for the master socket so up to you
you can rewire the master to give access to phone calls at other sockets if you wanted  posts on forum explain how to make minor changes
Message 4 of 12
When I got FTTP the copper cable to the house was removed. The Openreach engineer told me to remove my internal cable inc. old connection box and master socket myself!
Message 5 of 12
It is a relatively new house and only had FTTP installed, so no copper. I have no idea what to disconnect from where?
Message 6 of 12
I'm totally confused. You ask how to get rid of your copper wiring and then say you haven't got any copper wiring
Message 7 of 12
I’m confused as well. I am assuming that as a new house which came with FTTP, the old phone sockets would not be copper, I don’t know whether they are or not.
Message 8 of 12
If it’s like the last new build I looked at, the phone socket is next to the ONT.  This dates from when the phone was going to be delivered via the ONT and the socket was to connect the ONT to the internal phone extensions.  It’s an idea that is obsolete now, as the phone is delivered through the Smart Hub 2.
However, if this is the case, (and it may be a big if without seeing it), you could potentially connect the Smart Hub DV to one of the sockets and use it as an extension to a phone in another room.
Message 9 of 12
Are you sure they are phone  sockets and not an Ethernet distribution network , often with properties on new sites , the developer puts the ONT location in a awkward place ( cupboard under the stairs for example ) but they also provide Ethernet connectivity from under the stairs to several places , like behind the TV location, or into a bedroom ( or other  rooms )  …that way , if the customer wants , they connect the ONT under the stairs , to the appropriate Ethernet socket ( also under the stairs ) and at the other end of that Ethernet extension , they can plug in the  router into that Ethernet socket in a better location , basically so the router doesn’t need to be next to the ONT ….sometimes the developer provides the sockets but it’s a paid for extra , so if the client didn’t pay for Ethernet, the sockets exist but are not connected.
Similarly , if they are phone  sockets , you may find that you can plug the phone port ( with the appropriate cable ) of the SH2 into one of the wall sockets near the ONT , and plug your home  phone  into a socket at the other end of that extension cabling ( in the bedroom or living room etc ) that way you don’t have to answer the phone by climbing into the under stairs cupboard , but have it in a more convenient location.
Ultimately though , they are your sockets , nothing to do with BT or Openreach, and if it’s a new build , the cabling will not be visible ( installed before the interior walls were put up ) so why would you want to remove something hidden from view anyway , if the sockets themselves are not wanted you could remove them and re plaster but that seems somewhat unnecessary
Message 10 of 12
Phone sockets by definition can only be copper.
What is it you actually want to do?
If you have no incoming external copper service, the sockets are your responsibility to do with as you wish.
