Message 11 of 22
Re: Removal of old master socket
Spoiler
@400 wrote:
If I may add, the last safety course I did, we were told to consider any voltage dangerous, reason being not know state of persons health, pacemakers, shock across body etc. Meter it. Don't touch it.
I understand that once you are fibre, going back to copper wont happen? Wholesale have my address now as copper only by exception (not sure what that is). Removed my box, plastered over the wall box.
Gosh I better watch out next time I'm changing the 1.5v AA batteries in my kids toys!
Message 12 of 22
@gg30340
It is a worth while comment when you don't know who is fiddling away.
I will leave it at that.
Goodbye.
Message 13 of 22
Ridiculous elfin safety without common sense is the ruination of this country.
Message 14 of 22
@400 wrote:
@gg30340
Goodbye.
It was not a worth while comment when it was known what cable the OP was talking about.
Goodbye.
Message 15 of 22
Thank you for all the replies, I was primarily concerned with the fact that if there is a charge still present in the wire I would be cutting off and leaving in the wall, would this be a potential fire risk in any way? Many thanks.
Message 16 of 22
No, but if you are that worried, simply tape the ends with insulating tape.
Message 17 of 22
I may be a bit late i replying but you are able to  request Openreach come and remove the mastersocket and line if they are no longer needed.
We switched to  fibre and no longer use the copper line.  I contacted OR via the form and they called me and arranged an appointment to come and remove the mastersocket and copper line to the house.  There was no charge and it was very straightforward.
a llink to the Openreach form
https://www.openreach.com/building-developers-and-projects/altering-our-network/altering-our-network...
There is a thread on the ISPreview forum where several people have also done this
https://www.ispreview.co.uk/talk/threads/removal-of-old-bt-copper-cable.39610/
Message 18 of 22
Put a Wago/a connector on each wire and bury them or those Acorn thingies. It's not 240v 13A.
Message 19 of 22
Sorry to reactivate an old thread, but I am in the situation of wanting redundant copper removed after FTTP upgrade, so I tried the Openreach form mentioned.  It gives two options: existing project or new.  I couldn't raise a new project as this is restricted to certain categories and "end user" isn't one of them.  For existing projects, a reference has to be supplied in the form IS00000. I asked the ISP (Zen) that did the upgrade, but Openreach hadn't supplied them any project reference in this form.  I asked Zen if they could help but they just provided a link to the same Openreach form.
Since others have used the form without problems, has it changed in some way?  How did others deal with the problems noted above?
Message 20 of 22
Why, as a ZEN customer, are you posting on a BT forum about Openreach?
