Message 1 of 15
Telephone Socket Removal
So i have a telephone socket in a bedroom on the 1st floor and wondering if there is anyway i can completely remove this.
14 REPLIES 14
Message 2 of 15
Re: Telephone Socket Removal
If it isn't the master socket, it is entirely your responsibility to do whatever you like with it
Message 3 of 15
Is the bedroom socket a master NTE or an extension?  Is your "line" a traditional copper one or do you have Digital Voice?
RIC9380
Message 4 of 15
I’m honestly not sure just moved into the house today
Message 5 of 15
So could i just cut this and every other telephone socket would work and would it not give me a shock if i cut it.
Message 6 of 15
Can you post a photo of it here please? There are several versions of the master socket (which you certainly should not cut) depending on when it was installed.
RIC9380
Message 7 of 15
Message 8 of 15
Master socket (like mine) by the look of it.
The master socket is the one that will feed any extension sockets.  BT says:  It's always best to connect your BT Hub to the master socket if you can. This is where the broadband signal is strongest, before it goes through any other home wiring.
Not to be tampered with really.
Other, more technical members may be able to offer further advice.
RIC9380
Message 9 of 15
That is a main socket however although there are wires connected on the "output" there are no wires connected on the input. Suggest you find out where that cable goes to in your house and disconnect there before removing that socketm
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Message 10 of 15
Okay can i not just cut it anyway as we will never be using landline in the house.
