Message 1 of 3
Digital phone answer phone
Have just changed to fibre and received digital phones as the answer phone does not appear to auto kick when not answered how do I turn it on and should the tape sign be lit when a message has been left
2 REPLIES 2
Message 2 of 3
Re: Digital phone answer phone
If you go to MYBT then manage package then digital voice you should be able to set number of rings before answering service pick up call
From memory the symbol does illuminate when there is a message
Message 3 of 3
Hi @TSOne and thanks for posting.
You should be able to sort this following @imjolly advice. Can you let me know how you get on?
Cheers
David
