Message 11 of 15
Re: Telephone Socket Removal
Do you have broadband? Is it full fibre to the premises??
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Message 12 of 15
We have fibre built to the house which our internet is connected to the fibre wall box
Message 13 of 15
Re: Telephone Line
As long as you have full fibre to the premises and are not using your copper line for anything I don't see a problem cutting out that socket.
Message 14 of 15
Re: Telephone Line
So i can just cut it and it won’t electrocute me and do i need to tape up the ends or anything or can i just leave it?
Message 15 of 15
Re: Telephone Line
@kianteoli
You can just cut it. If its still connected to the exchange, there is only 50 Volts on it so its harmless.
