Message 1 of 4
Use an existing physical telephone with Full Fibre broadband
Hello, I can see a lot of discussion about copper/versus digital phone line, but not this specific question answered:
If I move to BT Full Fibre 900 with the Digital Alexa Phone (the only option in my upgrade wizard), how can I retain the physical telephone that I currently use? I don't mind if it uses copper or a digital connection (not the question I am asking here), I simply want to retain use of it.
Can this be directly plugged into the Phone socket on the Smart Hub 2, and if not what adapter do I need to enable this? How do I ask BT for this adapter to be included in my package?
Thank you.
3 REPLIES 3
Message 2 of 4
Re: Use an existing physical telephone with Full Fibre broadband
I think I've answered my own question with this article, which says I simply need to plug my phone into the Phone socket on the Smart Hub 2.
https://community.bt.com/t5/Home-phone-including-Digital/BT-Digital-Voice-a-better-way-to-keep-in-to...
Message 3 of 4
Message 4 of 4
covered before  just connect your existing phone to socket on back of SH2  phone sockets will not work without a wiring change
