Message 1 of 5
VOIP handset
Is it possible to deactivate a VOIP handset ? My PSTN has been reinstated after 3 months !!
4 REPLIES 4
Message 2 of 5
Re: VOIP handset
you can either go to hub manager an unpair the phone or you can use phone go to menu then phone setting and last entry reset and that will disconnect VOIP phone
Message 3 of 5
Re: VOIP handset
Deactivated by the phone menu - THANK YOU for your assistance
Message 4 of 5
Re: VOIP handset
One more issue, when battery runs down there is a piercing beep, anyway of switching this off ?
Message 5 of 5
Re: VOIP handset
either switch phone off by holding red phone symbol and if that is no help then take batteries out
