Thanks @5progface. On the other calls that you have seen this on, are they numbers that you have as contacts or random numbers?
Has it just been calls going to the voicemail or have you seen your own number appear when you are answering a call?
Michael
That's really strange, @5progface
I recommend speaking to our technical support team so they can check everything from our side and run through some troubleshooting with you.
Please come back and let us know what happens.
Chris
I'm disappointed to hear that you weren't able to get this sorted @5progface
I'd definitely recommend giving our team another try, or also try calling or using our text fault service, and we'll be able to get this checked out.
You can find all the details you need on our contact us page.
Peter
Thanks for coming back to us with an update @5progface
Please let us know how you get on when the next call goes to voicemail.
Leanne.
Call this afternoon went to voicemail.
On the handset, I pressed the calls button and Yes, my own number was displayed.
Checked my calls log on the website and my own number was logged as an incoming call.
