Message 11 of 13
Re: X42-F81 Handset - paging other handsets?
It is possible
1. Main button
2. Press RIGHT
3. "No Speed Dials Stored"
4. Press RIGHT again
"Internal Calls"
"All handsets" i.e. Page
Or scroll down until you find the handset you want to call.
MB
Message 12 of 13
Presumably this is from the handset , and if there is only one handset and it’s misplaced , this of no use , admittedly you have more than one
Message 13 of 13
So you do what I did (before I worked out how to page a handset) - I rang my home number from my mobile phone.
MB
