Message 21 of 22
Re: router for digital voice
thanks, that makes sense. my advanced settings page has the toggle for fttc/fttp visible but set to off (fttc). i guess that means that if and when Norfolk ever gets full fibre the firmware upgarde is installed, albeit i won't need to consider that when i get DV .
Message 22 of 22
"The confusion with the port 4/FTTP toggle is that Openreach are very keen to move people to Full Fibre at the same time as DV, where possible, so they have allowed people to think the two go together."
And BT has added to the confusion by claiming erroneously that "DV will allow them to do away with the old copper network"
