Message 11 of 12
Re: AC 2600 Mesh Disks - Will they work with full fibre?
Thank you, I was wondering that if we changed the settings on the Smart Hub 2 whether it would also affect the ability of the new hub to use digital voice but that is clearly not the case. Now I understand.
Thank you very much for your help.
Message 12 of 12
Thank you, that's great. I was wondering whether by changing the settings of the Smart Hub 2 whether it would affect the operation of digital voice but that is clearly not the case.
