Message 1 of 7
Adding a 2nd router
Hi. I currently have full fibre setup (direct to premises). I'm going to add a 2nd router for the loft. I've already had ethernet cable installed. My question is can I hook a 2nd router direct to the modem (I can see the Openreach modem has additional ports) or do I need to connect it from the BT Hub. Thanks
6 REPLIES 6
Message 2 of 7
Re: Adding a 2nd router
Connect to hub. Only 1 router connected to ONT
Message 3 of 7
You need to either configure the second router as an access point and connect LAN port to LAN port or configure it as a router and connect LAN of primary router to WAN of secondary router. If the latter, you either need to configure the second router's WAN port to DHCP or give it a static IP address outside of the DHCP range of the primary router and set the gateway address to 192.168.1.254. Set the LAN range of the second router to the 192.168.2.xxx subnet.
Message 4 of 7
Unless you already have a second router to re-purpose, it is unlikely that a second router is the best option for whatever it is you are hoping to achieve.
Message 5 of 7
I don't have a 2nd router yet. What would be the best device to add in this case. A wireless access point? Something from BT?
Message 6 of 7
Yes, a wireless access point would be a better and cheaper option if you just wish to extend WiFi coverage. Have a look at TP Link devices https://www.tp-link.com/uk/home-networking/access-point/
Message 7 of 7
Wireless access point.
https://www.tp-link.com/uk/home-networking/access-point/tl-wa801n/
That is single band, which is ideal in most cases.
TP Link do a dual band version is you really must have 5GHz as well.
@licquorice  has the link to all the models.
