Message 1 of 3
BT - Asus dsl-ac88u setup
Hi guys.
I’ve bought a new Asus dsl-ac88u router, because of I want to get rid off from the BT Hub.
I have FTTC service, 5C Wall socket.
Currently my BT modem connected to the 5C -> Gfast socket.
So I’ve disconnected the BT router, and I’ve connected the new asus router. I plugged the broadband cable to the DSL slot on the router. I started to set up a new connection, I’ve selected PPPOE, username: bthomehub@btbroadband.com password: bt.
settings saved, but it can’t connect to the internet. What’s wrong??
Any idea? TIA
Tags (1)
2 REPLIES 2
Message 2 of 3
Re: BT - Asus dsl-ac88u setup
Did you set VLAN Id to 101?
Message 3 of 3
I did now, thank you!
plus: I navigated to the "Administration" page and the "DSL Setting" tab within it.  On that page I set "DSL modulation" to "G.fast" and "ANNEX Mode" to "Annex A" and applied the changes.
working perfectly now!
thank you!
