Message 1 of 15
BT DNS Servers Dropping my Website
Hi
I have the BT Hub 6 and therefore have to use BT's DNS servers.
I have a website that I'm sure has suffered from spammy neighbours in the past couple of months (on the same IP block etc etc).
I'm not able to connect to my website  - the domain is simply not known. Yet I can get to it via a mobile network or VPN / Proxy. So it's not my BT Hub (although I did try turning off the firewall) and I reckon this narrows it down to BT's DNS servers.
How do I get my website re-listed?
Thanks in advance
Tags (2)
14 REPLIES 14
Message 2 of 15
Re: BT DNS Servers Dropping my Website
Assuming your web site is not anything illegal if you post the address on this thread forum user will be able to try and access it to see if it is in the unlikely event being blocked by BT or some other reason that you can not access it.
Message 3 of 15
The website is silklink.co.uk
Message 4 of 15
Unfortunately I am away from home at present and I am not using a BT connection so I am unable to say if it is working or not with BT, it is OK on my mobile,  but I'm sure some of the other forum members will report back on this.
Message 5 of 15
No problem here with BT DNS servers.
Message 6 of 15
@silklink
Wouldn't work for me using Edge, so I switched to Opera. Still no joy so I activated Opera's free VPN and we're good to go. One of the technical experts will have to advise as I'm too old!
and with the VPN activated:
Message 7 of 15
Thanks for checking. Yes I can connect with VPN. Also with mobile. As soon as I turn on WiFi on the phone in my home I can no longer access the site
Message 8 of 15
This worked for me in Edge : SilkLink – Web and Business Development Services  but I had to include https
Message 9 of 15
Interesting that it has worked for 2 respondents in Edge. I personally hate Edge and anything to do with Microsoft and the Internet. However it makes you wonder where BT are
Message 10 of 15
Works for me with Firefox, Opera, Chrome and Edge.
All without VPN
