Message 1 of 2
BT Disc keeps dropping conenction
Hi, my disc seems dropping its connection. All is fine (steady blue light) then periodically it starts flashing, then sometimes goes red, then after a while it comes back. My device (desktop) flicks to another disc which is further away with a less robust signal. This happens several times during the day.  I cannot work out what's up with the disc. I've tried rebooting etc but it hasn't cured it. The dodgy disc is hardwired to my hub, some 10m away.
Could it be...
  • Problem with the disc?
  • Problem with the wiring (run is quite long, but not bent around any silly sharp angles)
  • Problem with me?!
Looking at the event log I during the most recent outage I see....
15:34:09 WHW INFO A station (Disc47_Upstairs)IF[5G](70:97:41:69:19:49):STA(4A:AD:1C:3C:4F:63) join WHW infrastructure
15:34:09 WHW INFO A station (Disc47_Upstairs)IF[2.4G](70:97:41:69:19:48):STA(30:E1:71:05:48:B5) join WHW infrastructure
15:34:07 A device connected to Ethernet port 1
15:34:07 Wire Lan Port 1 up, Speed 100 Mbps
15:34:06 DHCP device Disconnected: 192.168.1.236, 4a:ad:1c:3c:4f:63, unknown
15:34:06 DHCP device Disconnected: 192.168.1.104, 30:e1:71:05:48:b5, HP0548B5
15:34:06 DHCP device Disconnected: 192.168.1.177, 70:97:41:b5:98:28, BT-WiFi-Disc-9828
15:34:05 A device disconnected from Ethernet port 1
15:34:05 Wire Lan Port 1 down, Speed 10 Mbps
15:34:05 LAN [DEL] ARP 192.168.1.236 with 4a:ad:1c:3c:4f:63 from br0
15:34:05 LAN [DEL] ARP 192.168.1.104 with 30:e1:71:05:48:b5 from br0
15:34:05 LAN [DEL] ARP 192.168.1.177 with 70:97:41:b5:98:28 from br0
Does this provide any insight?
Any advice gratefully received, thanks.
Will
1 REPLY 1
Message 2 of 2
Re: BT Disc keeps dropping conenction
Hi @WillC9999 I'm sorry about the problems with your complete wifi disc. When the light goes red is it solid or flashing?
Have you tried a factory reset on the problematic disc?
You can do this by pressing a pin into the small factory reset hole, holding down the button for 12 seconds.
Wait 2 minutes for the factory reset to complete.
Reboot the Hub by turning it off for 30 seconds and then switch it back on.
Neil
