Message 1 of 37
BT Halo HUB-Device Speed Difference
Hello
Just left Sky and took BT Halo with 900.
As a lot of people i have read, i am getting 900 to the Hub, but only 300 to my device (WiFi) sat right in front of it.
If i move into another room, it drops to about 80.
Have spoken to the help desk, and they say thats a normal  reduction they would expect to see.
Without being nasty, the help desk person did seem to be new at the job, they had to keep going to ask the supervisor.
Is just getting 1/3 of the "advertised" speed normal?
Thanks Mike
36 REPLIES 36
Message 2 of 37
Re: BT Halo HUB-Device Speed Difference
What's the max rating on the wireless card in your device?
Anonymous
Not applicable
Message 3 of 37
Sadly the 2018 smart hub 2 is not the most cutting edge router.
To get anywhere near 900mbps over wifi you'll need a wifi 6 router
Bizarrely EE which is owed by BT offer this but BT don't.
Message 4 of 37
Change the record!!
Message 5 of 37
AI Overview
+1
The iPhone 12 uses a Wi-Fi 6 (802.11ax) chip with 2x2 MIMO
Message 6 of 37
From google
Message 7 of 37
Also The iPhone 16 features a Wi-Fi 7 card, enabling support for the latest Wi-Fi standard. This includes the 2.4 GHz, 5 GHz, and 6 GHz bands, as well as Multi-Link Operation (MLO). T
Message 8 of 37
Also MacBook
Message 9 of 37
@Mikehalo
What band are you using? It's only on the 5GHz band that you'll get anywhere near the speeds you expect.
Message 10 of 37
5 GHz
