Message 21 of 37
Re: BT Halo HUB-Device Speed Difference
Sorry, something came up and I’ve been away all day.
Anyway, glancing over what’s become a busy thread, I would point out that if you’re that bothered about maximum performance cat 6 cable would be better.  Even when you get 866 Mb/s with Wi-Fi, the overheads are lower with cable, giving a better throughput.
Message 22 of 37
No not really, but i hoped it would improve reception in other rooms, but it hasn't
Message 23 of 37
I need it in other rooms, including upstairs, running cables isn't really viable
Message 24 of 37
checked on EE web site, the package with the 7 hub is £30 a month more
Anonymous
Not applicable
Message 25 of 37
BT EE and Plusnet are one and the same. If you're happy with the BT package and price then simply replace the BT router with the EE router. In a instant you've gone from wifi 5 to 6 with all the benefits that brings
Wifi 7 is nice but it costs but again you buy them on e bay for around £65.
...stick with the WiFi 6 router
Message 26 of 37
"No not really, but i hoped it would improve reception in other rooms, but it hasn't"
As I previously said, increasing broadband speed to the router will not make any difference to the WiFi speeds you get around your house.
If they are unacceptably too low in other rooms, you need a WiFi mesh system to provide a strong signal with the same SSID throughout, provided by strategically placed mesh transmitter units.
Message 27 of 37
I’m waiting for BT to  send me the discs and I will order a 7 hub.
I will report back with the results
Message 28 of 37
Are the EE 7 routers locked to EE, and will not work on BT?
Anonymous
Not applicable
Message 29 of 37
As mentioned beforehand, no difference whatsoever between BT EE and Plusnet.
The EE router is simply plug and play.
Anonymous
Not applicable
Message 30 of 37
BT black discs only work with the smart hub 2.
The will definitely not work with any other router
