Message 31 of 37
Re: BT Halo HUB-Device Speed Difference
Now that's a new fly in the ointment to consider .
I need reception in the other rooms, so it looks like the EE router is a no go.
Anonymous
Not applicable
Message 32 of 37
Not really...in the past I've bought wifi discs from Ebay and they worked perfectly subscription free when I had the SH2.
EE wifi 7 has it's own mesh system which looks like a smaller version of the wifi 7 router.
Obviously all available on e bay for around £60.
Message 33 of 37
Interesting video on youtube.
https://youtu.be/qLQGBHf_FW0?si=nVnCy1xE91nc6NIQ
Message 34 of 37
There is so so much wrong with that video!
Whole house, garden, garage and half the street covered by a Flint 4 - WiFi 7 router
Anonymous
Not applicable
Message 35 of 37
No it's pretty much spot on.
The SH2 deliverers the goods when wired no argument. But WiFi even with the discs is woeful.
It was cutting edge in 2019 but now it badly needs replacing.
Message 36 of 37
First MEGA boost would be to move the router from behind the TV! My thought on any BT engineer saying that is not a bad place to put the router are unprintable!!! None of the discs are in good locations, some absolutely appalling!
More mesh points does not always mean better connections and higher speeds!
On the plan he’s on, he’s never going to hit 150Mbps upload unless there is something (not completely unheard of) going on.
With the right third-party equipment you can get Wi-Fi speeds VERY close to those of a wired connection – not hypothetical, I’ve AX3000 devices that connect to the AX6000 router, and Wi-Fi 7 can be even better.
When performing a speed test, don’t put your testing device TOO close to the access point, 1m should be the absolute minimum, or the signal strength can be too high and/or the two Wi-Fi devices can interfere with each other.
When taking any speed-test, make sure you are actually connected to the Access-Point/Mesh-unit that you think you are using. Also, it’s necessary to actually check you have not connected to the 2.4GHz band. Also, also, make sure you are connecting to the same speed-test servers (there are at least four different servers, Leicester – Nottingham – Manchester – Ilkley, shown in the video!).
Also make sure you are being limited by the capabilities of the device you are using to make the test.
Message 37 of 37
I had a quick flick through it.  Seemed to consist of some numpty just repeatedly doing speed tests.  Nothing about the factors that really affect signal propagation and how to mitigate them.
