Anonymous
Not applicable
Message 11 of 14
Re: BT Hub 2 - use of 5 GHz or 2.4GHz
@Leeparsonswrote:
So your statement isnt true.
What statement by who "isn't true"?
Message 12 of 14
@Leeparsons wrote:
Well today i was fed up with my series x flipping from 5ghz to 2.4 mainly. So i change the setting on the router, to false it to 5ghz.
Then i get my father kick off, as hes samsung a14 wont except 5ghz.  Its actually not supported. Even thou it can transmit at that frequency. So your statement isnt true.
The Samsung S14 does use both 2.4GHz and 5 GHz according to the Samsung stats for that device.
Samsung Galaxy A14 5G | View Specs & Camera | Samsung UK
If your father's is not able to use both there must be a problem with the device.
When you scan for networks when the 2.4GHz on the hub is turned off does his phone see the BT Hubs SSid (name) ?
Message 13 of 14
Its A12. My bad. Its not my phone
Message 14 of 14
So how do disc work exactly then? Are they tied to specific hardware mac address
