Anonymous
Not applicable
Message 11 of 15
Re: BT Smart Hub 2 USB port trying to use a USB drive as storage
@zimmer4me
I don't use Windows so can't check myself, but Step 3 in this instruction says "You can choose between NTFS, FAT32, or exFAT for the file system"
Are you saying that it not true?
https://www.solveyourtech.com/how-to-format-hard-drive-in-windows-11-a-step-by-step-guide/
Message 12 of 15
looking into how to format exfat32 to fat32 will let you know....
Message 13 of 15
ok thanks for pointing me in the right direction I have solved it now.
There was a **bleep**-up by me in the first place when I misread the usb stick size. It was actually 128gb but I needed to reformat to fat32 with some freeware as my laptop would not give me the option as I had previously formatted in NFTS. After that I was mislead to believing that I needed to use \\192.168.1.254\"my label NAS" when in fact when I changed it to \\192.168.1.254\usb1 it mapped in explorer immediately . Hopefully this solution will help others thanks all
Message 14 of 15
I think that applies if you have not previously formatted in NTFS which I had done so the option was then not available
Message 15 of 15
 As posted in the first reply to the thread!
