Message 1 of 3
BT Smart Hub 2 showing an incorrect IP for a static device.
I've set a PC on my network to have a static IP; however, on the devices page on the smart hub, it shows up with the wrong IP. (It shows up with Static instead of DHCP on the router page.) Is there any way to change the IP on the router so that it's correct? I've previously setup port-forwards, and because of this, I've had to use the actual IP instead of selecting a device.
2 REPLIES 2
Message 2 of 3
Re: BT Smart Hub 2 showing an incorrect IP for a static device.
Forget the network view, it's about as much use as an ashtray on a motorbike. Always set a static IP on the device itself and port forward to the address rather than hostname.
Anonymous
Not applicable
Message 3 of 3
Your post seems a little contradictory. You say you've set a static address but then go on to complain that it's not showing as DHCP?
So have you actually set a static address on the PC itself, or simply reserved an address from the router's DHCP table?
If the latter, make sure you have random hardware addresses turned off in Windows.
