Message 1 of 2
BT Smart Hub 2
Hello all!
Hope all is well?
I understand that we cannot use BT Smart Hub 2 as Bridge mode - which is BTs choice.
However they enabled this on BT Business, if I was to buy a BT Business Smart Hub second hand and swap it over - would this work? BT business smart hub has modem mode (bridging) whereas residential does not
Want to use my Eero router - I don't fancy double NAT - and the hybrid connect is a great feature to have so want to keep my Smart hub as modem.. if that makes sense..
1 REPLY 1
Message 2 of 2
Re: BT Smart Hub 2
As far as I'm aware, hybrid connect won't work with the business hub and it certainly won't work with a hub in bridgeide anyway.
