Message 1 of 5
BT Smart Hub 6
I am having FFTH installed next week. 500/74 Mbps I have a BT Smart Hub 2 at the present time.  Part of the new equipment has been received from BT, namely two digital house phones and a length of CAT6 cable.  Attached to the latter is a short note saying that my Smart Hub 2 can be used for the new digital setup. This by using ethernet Port 4 which the engineer will configure for the installation.  I see that there has been a software update ( Think November 2022) to allow the Port 4 change/update.
Will the engineer have to perform a full reset on the hub when he re-configures Port 4 please ?  This would delete all my information.
Reason for asking is that I have quite a large number of Port Forwarding items that I use and I am trying to avoid a lot of extra work if possible !! It would be great if this information could be saved.
Many thanks
4 REPLIES 4
Message 2 of 5
Re: BT Smart Hub 6
Just need to go to hub manager then turn FTTP TO ON and then just restart hub not factory reset
Anonymous
Not applicable
Message 3 of 5
Re: BT Smart Hub 6
As above, do it yourself ahead of installation & there's no need for the installer to touch the SH2.
But where does the Hub 6 in the title come in?
Message 4 of 5
Re: BT Smart Hub 6
Many thanks for that. I'll do it myself.
Sorry about the "6". It was a typo. Should be Hub 2.
Maybe SH3 will be out later this year perhaps.
Thanks again
Message 5 of 5
Re: BT Smart Hub 6
Many thanks for that. Easily done.
