Message 1 of 10
Plugged Bt Hub 6 Into Smart Hub 2 For More Range, Have I Configured Everything Correctly?
Hi all.
Plugged my Hub 6 into a smart hub 2 for more range.
I initially configured the Hub 6 by putting a LAN Cable between that and my PC Only
Disabled DHCP, Firewall, Upnp and I also changed my server address range and my hub gateway IP address so both routers don't conflict on 192.168.1.254
Everything is working fine but I am unable to access my hub 6 router settings (to change wifi password etc) after I plug my smart hub 2 into it. Whenever I enter the IP address hub gateway I put in it simply times out. I must add though everything is working fine, I just cant access the hub 6 router
Why is it doing this and have I configured everything correctly?
I saw there was a link here that explains how to do this;
https://community.bt.com/t5/Archive-Staging/BTHub6-Smart-Hub-As-WiFi-Extender-or-AP-Access-Point-amp...
But It wont let me access the link sadly
thanks
9 REPLIES 9
Message 2 of 10
Re: Plugged Bt Hub 6 Into Smart Hub 2 For More Range, Have I Configured Everything Correctly?
can you access this post
https://community.bt.com/t5/Archive-Staging/Use-a-second-Smart-Hub-2-0-as-a-wifi-extender-whilst-kee...
Message 3 of 10
Hey thanks, that works.
I did all that but still cant access my BT HUB 6 Gateway when connected to the Smart Hub 2 for some reason
Anonymous
Not applicable
Message 4 of 10
What address did you use? It needs to be in the same range as the SH2 but outside the DHCP. Which IIRC is 192.168.1.63 or below.
Message 5 of 10
Tried 192.168.1.255 but didnt work
Range is 192.168.1.64 - 192.168.1.253
Also tried to change the server address range to custom and use 172.16.0.1 but didn't work either
Everything internet based works fine its just I am unable to access the HUB 6 when I connect it to the Smart Hub 2
If I disconnect everything and just leave a cable between the PC and HUB6 then 172.16.0.1 / 192.168.1.255 loads strangely
Message 6 of 10
You can't use 255, that's the broadcast address for the subnet. As @Anonymous says, it needs to be below 63
Message 7 of 10
@sunny808
if you read the link I posted @licquorice explains how to set up your HH6
Message 8 of 10
@licquorice
Thank you everyone I will give this a go later on today
I read the link but my understanding was that if the range was;
Anything outside of this would work
Since the smarthub uses 192.168.1.254  , If I set the hub6 to 192.168.1.255 that would be out the range
But thank you so much for your replies I will give this a go later on today
Message 9 of 10
255 is always the broadcast address of any subnet and can't be given to an individual device.
Message 10 of 10
@imjolly
Works perfectly thank you all for your assistance
