Message 1 of 4
BT Wholehome WiFi failure
May 2023
I have a SmartHub 2 and a 3 disc wholehome wifi network.    My wifi network keeps failing in 2 different ways, a few times a day the discs will all be showing blue lights but the wi-fi wont have any internet connection.  The other issue is that all 3 discs will drop off and show red lights.  They may or may not reconnect to the hub, rebooting the hub works, eventually.
I've had:
  • my line checked and reset;
  • Cfactory reset on the hub
  • hub replaced
  • all 3 discs factory reset
I still get hubs dropping off (all 3) and random gaps in the internet over wi-fi.
My cable connection to the hub works fine
I've had a BT network for some time but the service it provides seems to be getting worse
I also have Halo 3+ for all the good it does me
Can anyone help,  please.  I really dont want to move to move suppliers
3 REPLIES 3
Anonymous
Not applicable
Message 2 of 4
Re: BT Wholehome WiFi failure
@sws57wrote:
…I also have Halo 3+ for all the good it does me…
Your Halo 3+ includes support from Home Tech Experts, have you had anyone out to take a look?
Get the help you need, when you need it with Home Tech Experts
You'll get access to our Home Tech Experts available for in-home or contactless appointments in 2 hour slots, 7 days a week.
They can help with repairs or make sure your connection is perfectly set up. Plus, they'll come round once a year to make sure your broadband is working perfectly for how you use it. All at no extra cost.
Message 3 of 4
Thanks, I've had a visit from Home Tech the problem remains.   The Home Tech guys seem as baffled as I am.  I will be putting another call in but tbh its not been a great success so far.   Thanks  @Anonymous for the tip anyway.
Anonymous
Not applicable
Message 4 of 4
Ah OK, I see why it didn’t help now!
